Overview
The machine monitoring module provides real-time visibility into machine-level performance and enables state-based prioritization. It provides you with a comprehensive view of all machines on your line with their real-time status.
You can also view machine-level details and understand individual machine performance.
You can access the machine monitoring module from the main menu.
You will be displayed all machines of your line in a real-time view on the landing page of the machine monitoring module. This view represents the real-time status of your machines if they are cycling, down or idle.
You can view details of a machine for a specific period in the machine overview screen. For each machine, you will be displayed its:
Overall OEE and production
Availability, Performance and Quality KPIs
On the same screen, you can change the time duration to view machine performance for a different period.
You can view all parameters of a machine by navigating to the parameters section. You can either opt to view the parameters in a table form or a graph form.
On this screen, you will also be able to drill down to view aggregate downtimes and aggregate cycles of a machine.
You can also navigate to the heatmap view of cells and machines from the heatmap tab of the machine monitoring module. This will redirect you to the existing heatmap which will open in a new browser tab.
